Dries2
Apr 18, 2020Guide
RBR850 - Access Point + wired backhaul & security issues
Hi all, I created a topic earlier, describing my issues when combining the "Access Point modus" with a wired backhaul: https://bit.ly/2zbOgG2 The topic was automatically closed, so I needed to cre...
Apr 18, 2020Guru - Experienced User
What is the Mfr and model# of the ethernet switch in the configuration?
There is a known problem with RBS being connnected to swtiches in bertween with v10.11 FW. This already has been reported to NG and they are aware of it.
You can downgrade to v3.2.9.2 and use that FW with a switch in the middle, if not, keep current FW loaded and wirelessly connect the RBS until NG gets this fixed.
Thankl you.
