Dries2
Apr 18, 2020Guide
RBR850 - Access Point + wired backhaul & security issues
Hi all, I created a topic earlier, describing my issues when combining the "Access Point modus" with a wired backhaul: https://bit.ly/2zbOgG2 The topic was automatically closed, so I needed to cre...
Dries2
Apr 19, 2020Guide
Hi FURRYe38,
* My switch is an unmanaged switch (Cisco SG102-24 Compact 24-Port Gigabit Switch). It has green ethernet features, and I'm aware that this causes issues. That's why I connected both RBR850 en RBS850 directly to my router.
* My router is a Fritz!Box 7590, which is connected to a cable-modem, a CBN CH6643E (provided by the ISP);
Using the 'old' firmware (V3.2.9.2_1.2.4), this worked fine. I just opened this topic to mention that it doesn't work on the new firmware (V3.2.10.11_1.2.12) anymore.
I have indeed downgraded the firmware as a temporary measure. I have also logged the issue at Netgear.
Hi Kildare,
Very recognizable, I also have the issue that my network became open (unsecured). See my original topic here:
If I had the option, I also returned the Orbi. It's just too much money for what you get. I'm sure the hardware is fine, but the firmware has way too little options to deploy as a router (so I use it as AP), and the overall quality of the firmware is low (e.g. the wifi that suddenly becomes unsecure - I logged that early March!).
Apr 20, 2020Guru - Experienced User
You can't connect the RBS to a router. You have to connect the RBS directly behing the RBR or thru a non managed non green switch behind the RBR serially. It can't be parallel to the RBR. https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System
For some reason RBR and RBS have specific status data traffic that doesn't get passed thru when connected to a external router. The data flow has to come between the RBR and RBS directly between each other.
Also there is a problem with v10.11 FW in AP mode and using a switch in between the RBR and RBS. The status doesn't report correctly on the RBR for the wired RBS. I made NG aware of this in a bug report already.
So you might want to downgrade back to v3.2.9.2 for AP mode and a switch in the mix or use the current FW version and let the RBS wireeslly connect. That works. Also router mode on the RBR works with RBS ethernet connected with a switch. Whic you could use the RBR in router mode with your ISP modem/router with the option #2 in the following suggestion:
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Dries2 wrote:Hi FURRYe38,
Hi Kildare,
