sr7
Jul 07, 2021Aspirant
RBR850 - Airplay and uPNP/DLNA/Multicast issues
Just picked up an RBK852 and configured for AP mode connected to a C7000v2 (Wireless radios disabled). Devices connect without issue, however I can no longer see any AirPlay devices (a couple of ...
Jul 07, 2021Guru - Experienced User
Are all devices connected to the RBR or are some connected at the modem?
You might set modem only mode on the C7000 modem then configure the RBR for router mode and connect everything to the RBR.
- sr7Jul 07, 2021Aspirant
Every device is connected directly to the RBR. I have a WMC PC, HDHomeRun, and JBL Soundbar hardwired. 2 Roku devices and multiple iPhones connected via wireless.
The iPhones don't detect the Roku or JBL as Airplay even though they are fully compatible and were accesible when only leveraging the c7000.
I have the exact same experience when putting the c7000 into modem mode and factory resetting the RBR and reconfiguring cleanly as a router.
RBR and satelite are on firmware: V3.2.18.1_1.4.14
