dckiwi
May 10, 2022Guide
RBR850 - disappeared from Orbi app and Web interface gone
Until a couple of days ago my Orbi RBR850 was available in the Orbi iOS app, and I could login to the admin interface via www.orbilogin.com or 192.168.1.1. Now for some reason it has disappeared ...
rjward
May 10, 2022Tutor
I came here looking for help with the very same issue. My 750 stopped responding, and even after a factory reset it is still blocking all connections, and bitdefender total security went haywire. Pardon the jumbled reply - I am on a very small screen trying to resolve this
- dckiwiMay 10, 2022Guide
Did it disappear from the Orbi app as well? Interesting to hear that even a factory reset didn't fix it.
I also noticed that the front light is no longer illuminated - I feel like it is usually glowing white?
- rjwardMay 10, 2022TutorYes it disappeared from the app which is what clued me in something was up. I could not access via IP address from any computer although the network was functional. I did a factory reset and all hell broke loose.
- pr5889May 10, 2022Aspirant
Orbi App was working until 2 days ago. The Orbi RBR850 appears to be working without problem and connected to the internet but all of the sudden there is no way to access the router. The App will not connect to the Orbi router no matter what I do. Says that the router is offline or VPN is blocking it. Access anywhere doesn't work. Orbilogin and 192.168.1.1 doesn't work. I disconnected the satellites, did a power reboot but no success. I uninstalled and reinstalled the App but no success.
My next move is to factory reset the Entire Orbi system and put it back together.
Before I do this, anyone else have this happen and what did you do to fix it. VERY frustrating!!!
