dckiwi
May 11, 2022Guide
RBR850 - disappeared from Orbi app and Web interface gone
Until a couple of days ago my Orbi RBR850 was available in the Orbi iOS app, and I could login to the admin interface via www.orbilogin.com or 192.168.1.1. Now for some reason it has disappeared ...
pr5889
May 11, 2022Aspirant
Orbi App was working until 2 days ago. The Orbi RBR850 appears to be working without problem and connected to the internet but all of the sudden there is no way to access the router. The App will not connect to the Orbi router no matter what I do. Says that the router is offline or VPN is blocking it. Access anywhere doesn't work. Orbilogin and 192.168.1.1 doesn't work. I disconnected the satellites, did a power reboot but no success. I uninstalled and reinstalled the App but no success.
My next move is to factory reset the Entire Orbi system and put it back together.
Before I do this, anyone else have this happen and what did you do to fix it. VERY frustrating!!!
Vinmega
May 11, 2022Tutor
I am also in the same boat here.
Really hoping not to do a factory reset, I have 41 devices on here.
Orbi app will not connect to the router, says cannot connect. Internet works fine, but I have no insight if the satellites are working or what's going on. What is Netgear going to do?
Probably find out in a few days it was a massive hack.
