dckiwi
May 10, 2022Guide
RBR850 - disappeared from Orbi app and Web interface gone
Until a couple of days ago my Orbi RBR850 was available in the Orbi iOS app, and I could login to the admin interface via www.orbilogin.com or 192.168.1.1. Now for some reason it has disappeared ...
May 20, 2022Guru - Experienced User
Interesting.
So a 15-20 second press and release didn't work for you at all?
jrwashburn wrote:
1 minute w/r/t reset button (holding it 1 minute, powered on, vs. 15 or 30 seconds.)
jrwashburn
May 20, 2022Aspirant
That is correct. Multiple (I think 4 or 5) attempts at a 15 second reset did not resurrect listening on port 443. It did reset the config -- e.g. back to default wireless network and all settings gone -- which is why I say it made things worse. But nothing alive on port 443 after any of those attempts.
1 minute hold, disconnected from all ethernet except a direct wired computer, did it. Seems strange to me, but... that's what it took.
- FURRYe38May 20, 2022Guru - Experienced User
Ok Thank you for mentioning this and confirming it. Will pass this along and keep it on hand for those users with same problem.
Good to know.
