JudiJett
Jul 30, 2021Tutor
RBR850 - Disconnecting - Will moving router help?
I have the RBR850 with 1 RBS850. I'm having the same disconnecting issues I've read about in this forum. Tech support is in contact with me regarding the issue as I am not very tech savy and readin...
Jul 30, 2021Guru - Experienced User
YES. FYI, basments are not recommended places for wifi routers. Concrete and steel will prohibit good signal travel and performance. Main or 2nd floor is recommended for the base Wifi Router.
30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
