JudiJett
Jul 30, 2021Tutor
RBR850 - Disconnecting - Will moving router help?
I have the RBR850 with 1 RBS850. I'm having the same disconnecting issues I've read about in this forum. Tech support is in contact with me regarding the issue as I am not very tech savy and readin...
JudiJett
Jul 30, 2021Tutor
Great, I'll move it tonight or tomorrow. Much appreciated!
Jul 30, 2021Guru - Experienced User
Let us know how it turns out.
- JudiJettJul 30, 2021TutorWill do, going to give it 24-48 hours to verify all is good.
- FURRYe38Jul 30, 2021Guru - Experienced User
đ
- Mikey94025Jul 30, 2021Hero
If you're still having disconnection issues after relocating your Orbi, try setting your CTS/RTS Threshold to 2347 to maximize compatibility with older wireless devices:
- Go to the web admin portal at http://orbilogin.com/
- Click to the Advanced tab, Advanced left menu, Wireless Settings
- Set CTS/RTS Threshold to 2347 for both 2.4hz and 5Ghz networks
- Press Apply
See if that helps. If problems still persist, next try disabling AX mode for the 2.4Ghz band:
- Go to http://orbilogin.com/
- Click to hte Advanced tab, Setup left menu, Wireless Setup
- Uncheck "Enable 2.4G" under the top Enable AX section
- Press Apply
