4nthony
Aug 26, 2021Aspirant
RBR850 - DNS Options are Disabled (FW 4.6.3.9)
I updated to firmware V4.6.3.9_2.0.50 today. First thing I noticed was my DNS settings were gone and the radio buttons in the GUI were disabled: The text boxes for IP address input are enab...
4nthony
I'm looking through the app and I can't figure out where to disable Parental Controls.
Can you point me in the right direction?
Aug 26, 2021Guru - Experienced User
Try this, Obi app.
Select the House icon upper left corner.
Select Settings.
Select Parental Control
Select the slider button to disable PC...
This work?
- 4nthonyAug 26, 2021Aspirant
Thanks, I found the setting. I always forget Orbi puts some settings in that area.
As for the DNS settings, they are still disabled even though Parental Controls are also disabled.
However, I found a workaround. If I go into the browser developer tools, I can delete the "disabled" attribute on the radio button, fill in the IP addresses, and submit the form. The IPs will persist as long as I don't make any other changes on that page. Weird.
Maybe I'll do a reset of the router tomorrow and see if that helps.
- FURRYe38Aug 27, 2021Guru - Experienced User
Ok, ya, Seems like a factory reset maybe needed.
I would post about this also over here and lets see if we can get some more information on this:
https://community.netgear.com/t5/NETGEAR-Smart-Home-Parental/bd-p/en-home-smart-parental-controls
- 4nthonySep 01, 2021Aspirant
After a factory reset, both DNS options are still disabled, however the option to get from ISP is now selected by default.
I was able to enter my own DNS server's using the Chrome Developer tools trick I mentioned previously.
