vattu
Aug 12, 2023Tutor
RBR850 - Internet drops out
The internet connection stops working on the router from time to time. It can happen several times each day or a month can pass with no issues. Only way to get internet back is to restart the route...
vattu
Aug 12, 2023Tutor
Thank you FURRYe38 for taking your time helping me with this issue.
FW: V4.6.14.3_2.3.12
I think I've applied to try any beta versions. Haven't heard anything from Netgear yet.
ISP ONT Mfr: Inteno Broadband Technology AB
Model: XG6846
https://tinyurl.com/ypu43n5n
I have 1/1 Gbit per second. DHCP with public IP.
Internet cable is CAT6, and I've tried many cables, long and short ones.
I can't remember the color of the power LED when this occurs. The router ring LEDs are pulsing magenta, though.
Model: XG6846
Aug 14, 2023Guru - Experienced User
If the front LED turns PINK when this happens, means the RBR has lost internet services with the ISP ONT or the services has stopped working from the ISP:
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
Has a power off for 1 minute then back ON with the ISP ONT and router been performed?
Turn off and unplug modem.
Turn on computers and rest of network.
I would check with the ISP when this happens again to have them look at there ONT and services to see if they see anything during this time frame.
- vattuAug 14, 2023Tutor
Today it happened again. I could see on one of the computers that the internet connection dropped at about 5 pm (2 h ago). I followed your steps, and it worked again. I think it would work with just a power cycle of the router.
I've written to my ISP now and asked if they could see anything useful in their logs.
I'll write here again whenever I get any new information.
- FURRYe38Aug 14, 2023Guru - Experienced User
Power cycle BOTH ONT and RBR.
Yes, that's what I did. 🙂
I got a quick reply from my ISP. They could see instability in the link between the fiber converter & my router (either in any of the ports or the cable). I followed their suggestion to try switch to another port in their fiber converter.
Let's see if the connection gets more stable.
