tigerisak
Mar 19, 2020Guide
RBR850 - Major issues with packet loss
Hi. Im having major issues with what I believe is packet loss. When trying to WFH now in Corona-times I discovered that my brand new Orbi isnt super stable when using - Aircall, Zoom or FaceTime. It ...
cengo
Mar 19, 2020Aspirant
Same issue here. I am experiencing it since one or maybe 2 weeks, It worked before and I didn't change any network configuration.
During a support call with Netgear, I was advised to disable UPnP and to wait for a new firmware update.
After an hour or two (after the support call), I was sure that disabling the UPnP doesn't solve the problem and today I downgraded the firmware to V3.9.2_1.2.4. I am testing it right now.
I don't know if the firmware was / will be updated automatically, I don't have an option to enable/disable automatic firmware updates. (How can this be???)
I did did the downgrade of the main router (with 2 satelites) 15 minutes ago and I had no dropout since than, but I will feel secure only after another 10 or 15 mintues.
I am hoping, that the firmware will not be updated automatically again.
Mar 19, 2020Guru - Experienced User
If your system is at v3.2.9.2 then it should re-updated to v10.11. I would recommend after this happens on the RBS and RBR is to factory reset the RBS and RBR and then setup from scratch...
cengo wrote:Same issue here. I am experiencing it since one or maybe 2 weeks, It worked before and I didn't change any network configuration.
- cengoMar 20, 2020Aspirant
You are right, the system was upgraded again last night.
I did already a factory reset before I downgraded the firmware version, but without success. Do you really think it could make sense now? Was it successful for you or is it only a suggestion?
- DoctorAMar 20, 2020Luminary
Are you still experiencing problems? As of last night my problems are solved.
My I phone X Max and Gaming site disconnecting problems on wired PC desktop is solved since last night's automatic change.
I wish NG adds a simple click to stop further updates if people like me are happy with present configuration. Most electronic devices have that option. Are the other routers have the option? You can manually block the NG updating sites though.
No, I am not experiencing the problem anymore. Unfortunately, I can't compare the firmware versions: was there a new one (V3.2.10.11_1.2.12) distributed last night?
I hope that this status is stable now. I would say EVERY software has to have an option, to avoid automatic processes like this one. There are other "common" options missing for the RBR850, so maybe, they will arrive with future updates. But hey, are we the testers? I am not amused. This incident cost me a lot of time and trouble.
