tigerisak
Mar 19, 2020Guide
RBR850 - Major issues with packet loss
Hi. Im having major issues with what I believe is packet loss. When trying to WFH now in Corona-times I discovered that my brand new Orbi isnt super stable when using - Aircall, Zoom or FaceTime. It ...
DoctorA
Mar 20, 2020Luminary
Are you still experiencing problems? As of last night my problems are solved.
My I phone X Max and Gaming site disconnecting problems on wired PC desktop is solved since last night's automatic change.
I wish NG adds a simple click to stop further updates if people like me are happy with present configuration. Most electronic devices have that option. Are the other routers have the option? You can manually block the NG updating sites though.
cengo
Mar 20, 2020Aspirant
No, I am not experiencing the problem anymore. Unfortunately, I can't compare the firmware versions: was there a new one (V3.2.10.11_1.2.12) distributed last night?
I hope that this status is stable now. I would say EVERY software has to have an option, to avoid automatic processes like this one. There are other "common" options missing for the RBR850, so maybe, they will arrive with future updates. But hey, are we the testers? I am not amused. This incident cost me a lot of time and trouble.
- FURRYe38Mar 20, 2020Guru - Experienced User
There were no changes to v10.11 FW. The changes were made to NGs cloud servers which apparentlly NG Orbi AX FW interacts with. v10.11 was removed temporarily from the auto update servers so NG and those effected could troubleshoot the problem. NG found the from to be on there side with there cloud systems. They corrected the problem there only. NG put v10.11 back on the auto update servers and ask everyone to have there systems check for the FW if they were already at v3.1 or v3.2.9.2.
Most all users since 3/19 have been reporting that there systems are working again on v10.11. This issue is fixed now.
cengo wrote:No, I am not experiencing the problem anymore. Unfortunately, I can't compare the firmware versions: was there a new one (V3.2.10.11_1.2.12) distributed last night?
- cengoMar 20, 2020Aspirant
Thank you for your explanation!
Good to know some background information :)
