iqi
May 22, 2022Aspirant
RBR850 - Need help preventing internet access to a NAS device
I used to have an Asus router for the longest time - it had ability for me to configure certain devices (e.g. NAS) from accessing the internet. But devices within the network could access the NAS. ...
- May 22, 2022
The tests I have run do not support that assertion.
I set up total blocks on two computers on my network.
'Any', ports 1-65535, IP address, and 'Always'.
After clearing cache and the hosts file, neither computer could reach anything on the internet.
No web sites, no software update sites, etc.
(Note that 'ping' [ICMP] is neither TCP nor UDP, so service blocking does not stop ping.)
However, both computers could reach web sites on my LAN (printer and Pi-hole DNS server)
I could telnet into the Pi-hole, which is how I know that it was 'dead' on the internet.
So, local access in/out of the blocked computers - fine. Internet access out of the blocked computers - dead.
Was this the service block that you set up on the NAS and it failed to work?
(My ancient RBR50 Orbi may not be identical to your more recent model.)
iqi
Thanks CrimpOn. But as I said, that's not what I want. "Block services" blocks access to the NAS from local network devices. the requirement is:
- NAS should not be able to access traffic to the internet
- NAS should be able to communicate with local network devices
CrimpOn
May 22, 2022Guru - Experienced User
- iqiMay 22, 2022Aspirant
thanks for spelling out the process. that did the trick. thank you.
- FURRYe38May 23, 2022Guru - Experienced User
Please mark your thread as solved so others will know.
