sas123
Nov 04, 2020Star
RBR850 - no access to interface
I have an RBR850 WiFi 6 with one satellite. I have a lot of smart home devices on the nework (over 80) As of a few days ago, I cannot access the router interface via iPhone app nor can I access ...
Nov 07, 2020Guru - Experienced User
Yes Apple has put some new features in to iOS 14.x Sounds like NG has also adjusted for this.
Thanks for letting us know. Hopefully this helps others.
skeelo wrote:I think I have it figured out - at least this is what worked on my device (iPhone 10, software version 14.1):
1. Delete any and all Netgear apps - I had the Orbi app (home system) and Nighthawk app (cabin system)
2. Download the Orbi app from app store
3. Open app from device, NOT from app store
4. Follow prompts (e.g., allow network access, allow location access, etc.)
5. Sign in - interestingly the old sign in (email address and Netgear password) no longer works, I had to sign in with the admin account information and password as if I was logging in from my computer's web browser
Once signed in you should have access to all the same features as you did previously. My guess with the iOS14.x upgrades there are some changes to security that are creating these issues.
kevinroy1974
Nov 08, 2020Tutor
I have trhe RBK853 and have been seeing the very same thing, if i leave it a bit, say a day or so I cannot get to the admin interface, I also cannot get on the orbi app, I use the Orbi App on Android not on IOS.
I notice I can ping the router no problem and a port scan shows its still listening on port 80 and 443 but no way to connect to it at all. Other than that everything operates as expected Wifi doing what it does internet fine etc just no management and no use of the features I nwant to use in terms of shuttings kids internet off etc when i want as the app is unresponsive.
If I reboot it lets me in again, but again only for a day or so (sometimes just hours)
Its almost like the web server for the interface is crashing.
K
- FURRYe38Nov 08, 2020Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?Has a power off for 1 minute then back on been performed since last update?
Has a factory reset and setup from scratch been performed since last FW update?What browser are you using?
Try a different browser.
kevinroy1974 wrote:I have trhe RBK853 and have been seeing the very same thing, if i leave it a bit, say a day or so I cannot get to the admin interface, I also cannot get on the orbi app, I use the Orbi App on Android not on IOS.
K
- kevinroy1974Nov 09, 2020Tutor
Hello,
I am running firmware 3.2.16.6, Internet service providers modem is a virgin superhub 4, it has been powered off and funnily enough if i power off the modem and the router it works but only for a bit as per the previous people on the thread.
As far as firmware reset its only 2 weeks old, it flashed on the inital boot up of the system,
I have tried it with Chrome, IE, Edge etc, this is not a browser issue, the unit is unresponsive on both http and https and this explains why the app doesnt work, it never gets a response.
I can ping again as others have said it pings fine. Just have no access to web interface, not even responding if I telnet to port 80.
If I dont reboot everything else runs fine, internet access good, wifi good just no access to the admin interface or from the app.
If I reboot I get access to both the web interface and the app works but again only for a short period of time usually a day or so.
This very much looks like the web interface crashing.
Many thanks
K
- FURRYe38Nov 09, 2020Guru - Experienced User
What mode is our modem working in? Router or Bridge mode?
How was the FW updated? via routers web page or Orbi app?
kevinroy1974 wrote:Hello,
Many thanks
K
