sas123
Nov 04, 2020Star
RBR850 - no access to interface
I have an RBR850 WiFi 6 with one satellite. I have a lot of smart home devices on the nework (over 80) As of a few days ago, I cannot access the router interface via iPhone app nor can I access ...
Dec 01, 2020Guru - Experienced User
Setup with out any IP address reservations and IPv6 disabled.
sas123
Dec 01, 2020Star
Mine still remains stable for more than a week after manual update to V3.2.16.22_1.4.9.
What I don't undestand is all these recommendations of disabling features (e.g. IP reservation, etc.). With all due respect, those are not real solutions but perhaps turn arounds. It's like paying full price for a Ferrari but being told you can only use 4 cylinders; otherwise, the car is going to leave you stranded.
This requires a real fix by Netgear.
I can't comment on other people's experiences; but for me, it seems the above firmware has fixed my issue with regard to lack of access to the interface.
Cheers,
- FURRYe38Dec 01, 2020Guru - Experienced User
Just troubleshooting steps is all.
Do you any IP reservations? Just curious.
I don't have any set on mine. I guess I can add some and see.
sas123 wrote:Mine still remains stable for more than a week after manual update to V3.2.16.22_1.4.9.
Cheers,
- sas123Dec 01, 2020Star
Yes, I do have one third of my network (over 80 devices) with reserved IP addresses.
Ok, good to know. Ya, seems like a clean manual load is a good step. I've never had good faith in using the updater on the RBR. I prefer loading the files myself and either power OFF the RBR and RBS for 30 seconds or just doing a full factory reset and setup from scratch.
sas123 wrote:Yes, I do have one third of my network (over 80 devices) with reserved IP addresses.
