sas123
Nov 04, 2020Star
RBR850 - no access to interface
I have an RBR850 WiFi 6 with one satellite. I have a lot of smart home devices on the nework (over 80) As of a few days ago, I cannot access the router interface via iPhone app nor can I access ...
Apr 07, 2021Guru - Experienced User
Try different wired devices along with different browsers to access the RBRs web page?
Power OFF the ISP modem and RBR for 30 seconds then back ON then try to access the RBRs web page?
51Alan
Apr 07, 2021Guide
Not yet. I'm going to sit on it for a while (as long as everything else is working) and see if it comes back on its own. If I have a problem, I'll shut off the power and boot it back up to see if that restores connectivity.
I've been using this RBK753 for almost half a year now and I'm impressed with the range, and with the speeds at the edges of the range (I have to use it daisy-chained because of the layout of our house) but there are annoying things like this, and like a few 2.4ghz devices losing connectivity or running into DNS problems (which has let me to try the CTS setting adjustment), which give me pause as to whether to recommend it to anyone else. I don't seem to have problems with "major" devices such as the Macs, the PC, Roku, TiVo, the iPads or the like, but devices such as the Honeywell thermostat, the Hunter irrigation controller, the Ring security camera, one or two smart speakers -- those drop connectivity too often and restore it only after a reboot of the RBR. (I've already disabled AX on the 2.4ghz band.) This latest issue -- being unable to access the interface either through the app or through a browser -- just seems to have popped up out of the blue and is another annoyance. We'll see if it grows into a problem.
