sas123
Nov 04, 2020Star
RBR850 - no access to interface
I have an RBR850 WiFi 6 with one satellite. I have a lot of smart home devices on the nework (over 80) As of a few days ago, I cannot access the router interface via iPhone app nor can I access ...
Sean_Orbi_dude
Oct 16, 2021Aspirant
I have the same issue.
Using the RBR850. No access to web interace via browser/phone app.
Restarting/power cycling the router allows access for a few minutes and then i am locked out.
Is this more a hardware problem? Seems very prevalent.
Has anyone come up with a permanent solution? It's quite ridiculous that a restart/power cycle is needed jsut to access the web interface. Can Netgear get their act together?
Oct 16, 2021Guru - Experienced User
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch.
I would power OFF the ISP modem for 1 minute. Factory reset the Orbi router and power it off. Power ON the ISP modem and let it sync. Then power ON the Orbi router and walk thru the setup wizard again using a wired PC and a web browser.
- Sean_Orbi_dudeOct 22, 2021Aspirant
Thank you - Yes factory reset attempted and no go.
Things tried and failed to fix:
- Factory reset (pin in back, power light green --> amber flashing)
- Power cycle (modem + orbi router)
- RMA router+satellite (ie unlikely hardware issue)
- Login attempts on multiple devices/OS's including iOS and windows 10 on both wireless AND wired (direct to router Cat 5e cable)
- Manual firmware update within that 3min i have within the router admin page, currently on : V4.6.3.16_2.0.51; Post manual update 1x power cycle repeated. (2min off modem+router then turn on again)
Pls help. It's a real pain to restart/reboot router. I have timed it - the failure occurs after only 3min post-reset.
IE reset --> can login via windows 10 comp via cable AND iOS orbi app --> total duration 3min then it stops working.
? Some software loop clogging the system ?
Sometimes if i leave the 192.168.1.1 tab open after it fails, it will show part of the web interface and then stop.
