bobswinkle
Sep 22, 2024Follower
RBR850 - Not blocking services
I have two RBR850 connected in a mesh. I'm trying to setup the block sites and block services features. Neither are working as expected. The block services one is most important to me. I want to ...
Sep 23, 2024Guru - Experienced User
the https causes issues and basically ruined blocking on the netgear routers.
https://aws.amazon.com/compare/the-difference-between-https-and-http/
For most, using a DNS blocker works better. I use pihole but you could use a direct service like cloudfare or opendns
