SumatraKhan
May 01, 2023Follower
RBR850 - Orbilogin.com Missing Functions
I have the RBR850 version, but it wouldn't pull up in the associated products field
According to the manual, Orbilogin.com should have settings for an IOT network, and a 'Show Statistics' button under the 'Advanced' tab, but neither exists when I log into the orbilogin.com. Anyone know why?
I'm really hoping this isn't a, "need the pro version of the router", because these things weren't cheap enough to be missing these basic options.
1 Reply
What FW do you have loaded?
Sometimes NG uses the same template user manual for there Orbi systems though not all models have same features. Only the 9 series has a IoT Network.
There should be a Show Stats button on the Advanced tab though.
What browser are you using? Does this happen in other browsers?
