Mickesj
Feb 03, 2024Aspirant
RBR850 - Poor download speeds on Wi-Fi
Hi guys, Having some serious issues with download speed when on Wi-Fi. Have 500/500 Internet link and when I use cable connected directly to router i get about that so just Wi-.Fi that's affected...
Feb 03, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰️
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
https://www.increasebroadbandspeed.co.uk/realistic-speeds-wi-fi-5-and-wi-fi-6
https://www.wiisfi.com
https://www.duckware.com/tech/wifi-in-the-us.html
https://support.google.com/fiber/answer/6250056#zippy=%2Cmobile-devices-wi-fi
Mickesj
Feb 04, 2024Aspirant
Thanks for the tips and advice!
Inteno XG6846
Using CAT 6 STP
2600
What is the distance between the router and satellite(s)?
Over 30 feet
Yes
Only when on wireless (wired gives full up/down speeds)
Tried changing them around, no change.
Tested this, no change.
Also, did a test where I disabled main Wi-Fi and enabled IoT wireless network (forced 5Ghz) - same results as with the main Wi-Fi.
- FURRYe38Feb 04, 2024Guru - Experienced User
Inteno XG6846
This checks and indicates there is a router built in here. Is this bridged or in router mode?
FYI:
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Using CAT 6 STP
2600
For this size of home, the RBR and just one RBS would be needed. Maybe two with power settings set to 50%.
What is the distance between the router and satellite(s)?Over 30 feet
Yes
Does this happen with both wireless and wired devices?Only when on wireless (wired gives full up/down speeds)
Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.Tried changing them around, no change.
Points to maybe something with the wifi device. When speed testing, make suure that when you are near the RBR or RBS, disable the wifi radio on the wifi device for 5 seconds then re-enable it then speed test. This ensures the wifi device locks on ot the nearest signal for best speed test performance.
Last app I had was WiFi Sweetspots however not sure if that app works anymore.
