DudleyV's avatar
DudleyV
Follower
Jan 25, 2023
Rbr850 - rbs 750
Hey,
I have a new installation with a RBR850, a RBS850 and a RBS750.
The RBR850 and RBS850 are working fine with a wired backhaul.
I've tried adding the RBS750 and it received the SSID but for the rest it isn't doing anything. No devices can connect to it and the area where I've placed the RBS750 is still a dead zone. I can still access the webpage with the default username and password instead of my credentials. It is also still showing up as out of sync.
The RBR850 is in AP mode and the router and the satelittes are on the same FW version (V4.6.14.3).
Already tried factory resetting the RBS750 multiple times.
The setup is as follow: isp router connected to a cisco switch on which all RBR and RBS are connected.
Any idea how I can get the RBS750 working normally?
Thanks
1 Reply
  • FURRYe38's avatar
    What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
    Try turning OFF the 8 series RBS and leave the 7 series RBS alone and see if it works thru the RBR...
