Retired_Member
Apr 26, 2022RBR850 - Satellites will not appear in web interface
I've had these set up for a while in Router mode. Satellites worked flawlessly. I moved them to a hardwired back channel. Still worked flawlessly. But when I flipped them to AP mode they all three...
- Apr 27, 2022
Retired_Member wrote:I have all three (router and both satellites) plugged into a switch and the switch plugged into the LAN side of a modem.
Are you saying the satellites need to connect to the router and the router then connects to the LAN side of the modem?
Apr 26, 2022Guru - Experienced User
how do you have everything wired.
In ap mode it should go
router (primary)---->RBR wan port---->lan port on rbr---->switch---->satellites
Retired_Member
Apr 26, 2022I have all three (router and both satellites) plugged into a switch and the switch plugged into the LAN side of a modem.
- plemansApr 26, 2022Guru - Experienced User
the satellites need to come from the lan side of the router when connected with a wired backhaul. And the router in ap mode should have its internet coming into the wan port.
So internet connection----router wan port---->lan ports-----switch/satellites.
The satellites can be connected to the switch or the router. They just need the direct connection to the lan side
- Mikey94025Apr 27, 2022Hero
- Retired_MemberApr 27, 2022
I marked this as "the" solution because anyone with this issue should start here...but the others were the ones that helped me "understand" what this says.
It takes a village to build a network.
Thanks gents!
- plemansApr 27, 2022Guru - Experienced User
Glad you got it resolved!
Let us know if you have other issues and we're happy to help
