TheGrumpyGent
Dec 09, 2021Tutor
RBR850 - Skip SPC Activation?
Hello! I'm a new RBR850 owner who mistakenly turned on Smart Parental Controls (which prevents Access Control from working on the Orbi). I did a factory reset and everything is setup and working...
Dec 09, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the SPC product. Most of the people who watch that forum are more likely to have experience with Smart Parental Controls and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/NETGEAR-Smart-Home-Parental/bd-p/en-home-smart-parental-controls
- TheGrumpyGentDec 09, 2021TutorI’ll give that a shot, I posted here as it’s not so much about the Parental Controls as getting the router’s Access Control to work.
