TheGrumpyGent
Dec 09, 2021Tutor
RBR850 - Skip SPC Activation?
Hello! I'm a new RBR850 owner who mistakenly turned on Smart Parental Controls (which prevents Access Control from working on the Orbi). I did a factory reset and everything is setup and working...
CrimpOn
Dec 09, 2021Guru - Experienced User
I had a similar issue where the app thought I had enabled SPC (or was it Circle?) and I would just ignore that pop up. Tedious, but I seem to remember being able to use the app.
You requested the refund here:?
https://kb.netgear.com/000063635/How-do-I-get-help-with-my-NETGEAR-subscription-service
TheGrumpyGent
Dec 09, 2021Tutor
Honestly I just put in a support case, as I also want to make sure the pop-up preventing me from looking at devices on the app goes away.
