ckao
Oct 13, 2021Follower
RBR850 - Unable to access the router interface after enabling Access Control.
RBR850 AX600 - I found a device connected to my wifi today. I then enable Access Control and blocked the device using the web interface. A few minutes later, I'm not able to connect to the wifi rou...
Jan 12, 2022Guru - Experienced User
Any progress on this?
ckao wrote:
RBR850 AX600 - I found a device connected to my wifi today. I then enable Access Control and blocked the device using the web interface. A few minutes later, I'm not able to connect to the wifi router (gateway). The only way I can get to it quickly is the power off the router and turn it back on. Then I only have a minute to do what I need to do before it times out.
Disabling Access Control allows me back into the router again without any issue.
I am running the latest firmware so I'm not sure what's going on:
Firmware Version
V4.6.3.16_2.0.51
If anyone has a solution please let me know.
Thank you!
