bdoubledizzle
Jan 25, 2024Aspirant
RBR850 - unable to upgrade firmware
My RBR50 has an old firmware installed (v4.6.13.3) and neither the iOS app nor the orbilogin.com interface show any upgrades as being available, despite v7.2.6.21 being available. When I try manua...
- Jan 26, 2024
What browser are you using to download the FW files? If you have RBS along with the RBR, you need the two separate files, RBS and RBR. Be sure your unpacking the FW files from the .zip files to reveal the actual .chk files that have to be sent using the RBS and RBR web pages.
bdoubledizzle
Jan 26, 2024Aspirant
My Orbi WiFi router is definitely RBR850.
And I wondered the same so downloaded firmware zip file 3x. Same result every time. đ
Jan 26, 2024Guru - Experienced User
- bdoubledizzleJan 26, 2024AspirantTHANK YOU SO MUCH - I am a big dumb animal and didnât realize there was different firmware for router vs satellite. Duh.
Worked like a charm, hugely appreciate your helpful and generous assistance - happy Friday to you!- FURRYe38Jan 26, 2024Guru - Experienced User
Yay. Glad it working.
If its all updated, Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. đĄ
