mihealy54
Apr 18, 2020Aspirant
RBR850 - Upstream BW low = Requires Daily Reboot to get back to normal throughput
Hello,
Re-posted with new Title "RBR850 - Upstream BW low = Requires Daily Reboot to get back to normal throughput"
I am having trouble with my Orbi AX6000 (RBR850RBS850). I am getting very frustrated with this product. I have swapped it out at Best Buy 3-times for misc problems, why is the quality so low?
Now I am once again having trouble with this product
Problem Definition::
1) Initially, right after a clean reboot. The bandwidth upstream (me-2-ISP) and downstream (ISP-2-me) is great DS=300Mbps/US=300Mbps. I have direct fiber-to-the-home, I pay for DS=300Mbps/US=300Mbps
- The by the end of the day (14-16hrs later) the bandwidth has been reduced in the Upstream (me-to-ISP), DS=300Mbps/US=62Mbps.
- I have spent huge huge amounts of time debugging with the ISP Provider, removed the Orbi Router from the system 5times, 100% proven the ISP Provider is perfect (correct BW).
- It has absolutely no problems with ISP traffic congestion, my provider guarantees DS=300Mbps/US=300Mbps, I have removed Orbi in the middle of the day when traffic peak, PC plugged into ISP ONT Box (no Orbi) == perfect bandwidth (DS=300Mbps/US=300Mbps). Plug Orbi back in, reduced BW = DS=300Mbps/US=62Mbps, both connected to LAN ports and WIFI, US=60Mbps. Really annoying
I am really frustrated
Have spent hundreds of hours debugging this product
Why so much effort?
Why is your quality so low?
Why have you charged me the most amount of money in the industry for a router product that does not work?
I opened a case with Netgear, no reply, no case, nothing?
Sure, sorry, no problem, please delete the "RBR850 - Upstream BW low = Requires Daily Reboot to get back to normal throughput" case, thank you
So we see your posts. Please use only one post to start out:
Please post here and we'll try to help you out.
Thank you.- mihealy54Aspirant
