bmacmillan
Feb 24, 2022Follower
RBR850 - WiFi Backhaul constantly disconnecting
I recently moved my office in my house and am relying on the backhaul connection between the RBR850 and one of it's sattelites to provide ethernet connectivity to my desktop.
I'm having an issue where every once and a while (ranging from 30 seconds to 5min), I'm still able to ping my gateway (across the backhaul) but can't ping google (8.8.8.8 for example).
From another PC wired directly to my internet I don't drop a single packet, only when the ping is sourced across the backhaul.
I'm at a complete loss for what to do, any help would be appriciated.
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?What is the size of your home? Sq Ft?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many? - Cortez254Aspirant
@eTenet Portal wrote:I recently moved my office in my house and am relying on the backhaul connection between the RBR850 and one of it's sattelites to provide ethernet connectivity to my desktop.
Switched to AP Mode and running through an Untangle firewall. It gives me much more control and logs everything to a local syslog instance. I'm also out of forced and poorly tested firmware updates.
Any progess on this?
