Ragutis
Apr 22, 2024Tutor
RBR850 / RBS 850 - wi-fi band choice / selection
I have the RBR850 plus 2 RBS-850 satellites. My issue arises from security cameras, specifically Logitech 961-000490 Circle View models. The cameras state they need the 2.4 GHz band - we have the 2.4...
CrimpOn
Apr 22, 2024Guru - Experienced User
Ragutis wrote:
nearer ones connect to the 5 GHz and do not function.
This is categorically impossible. As mentioned in the original post, this camera specs clearly state that it contains a 2.4GHz WiFi:
It cannot detect a 5GHz WiFi signal. It cannot connect to a 5GHz signal. Does the Orbi 'app' or the Orbi web interface indicate that these cameras are connected at 5GHz?
FURRYe38 is correct that the current 850 firmware supports creation of a WiFi SSID (called IoT) that can disable the 5G frequency. This may solve the problem, but it is not because the cameras were connecting at 5GHz.
- RagutisApr 27, 2024Tutor
Both the app and the web interface show the cameras connected to the 5 GHz band
- CrimpOnApr 27, 2024Guru - Experienced User
This is the camera, correct?
https://www.logitech.com/en-eu/products/cameras/circle-view-security-camera.961-000490.html
If this device is connecting at 5G, it's a miracle
Yes, that's the one. Doesn't make much sense really
