Scottrya
Mar 18, 2020Follower
RBR850 & RBS40V Compatibility
Is it likely that the RBS40V will be made compatible with the RBR850. Just upgraded my mesh network but unable to add the Alexa Satellite, which is a great piece of kit. Just don’t want to unnecessari...
ekhalil
Mar 18, 2020Master
It should work now if you connect the RBS40V wired to the RBR850.
Wireless connectivity to original Orbi will come later as promised by Netgear.
