ArcaneAnomie
Mar 07, 2022Aspirant
RBR850 / RBS850 | Wired Backhaul | Satellite Limited to 100Mbps
Hoping someone else has had this issue and may be able to steer me in the correct direction. I have an Orbi RBR850 and RBS850 setup. The RBS850 is wired to the RBR850 via in-home ethernet wiring ...
- Mar 10, 2022
100% agree with plemans. I had this exact same issue and was banging my head almost literally againt the wall to solve this. It turned out to be a small 1.5Ft patch panel cable that must have had a tempermental break or termination. I replaced it (while trying to troubleshoot the in-wall cable) and suddenly the issue was gone permanently. Replaced that patch cable and I haven't had an issue again since.
Mar 07, 2022Guru - Experienced User
You said "through in home wiring".
I've seen numerous times where in home wiring had issues either with cheaper cable used or with ends that weren't crimped right/well enough and caused speeds to drop from gigabit to 10/100mbps connections.
Any chance you have a 100ft ethernet cable laying around?
Or even just one log enough to hardwire in the satellite with a known good cable?
That way you can check if its actually a satellite issue or just a cable connect not being the issue.
Or even if you're using a switch in between the router---satellite to remove it for testing.
behtyas
Mar 10, 2022Initiate
