darthwhat57
Apr 08, 2022Aspirant
RBR850 / RBS850 After Firmware update the Satellite does not display in admin console but works
Just got the AX6000 kit router with satellite, I set it up using the phone app, that all went well. I updated both of the devices firmware (latest) and now the satellite does not show in the admin co...
Apr 08, 2022Guru - Experienced User
Try powering OFF the RBR for 30 seconds then back ON.
If this fails, try a factory reset. Press the reset button on the RBS for 15 seconds then release. Resync wirelessly to the RBR while in same room as the RBR. Check the RBS web page.
darthwhat57
Apr 10, 2022Aspirant
Nope neither worked. All it did was change the IP of the satellite. Appreciate the suggestions though.
- FURRYe38Apr 10, 2022Guru - Experienced User
Where did you change the IP address of the satellite and what IP address did you change it too?
- darthwhat57Apr 10, 2022Aspirant
It changed on its own when I powered down the router.
- FURRYe38Apr 11, 2022Guru - Experienced User
So what IP address did it change to?
