darthwhat57
Apr 08, 2022Aspirant
RBR850 / RBS850 After Firmware update the Satellite does not display in admin console but works
Just got the AX6000 kit router with satellite, I set it up using the phone app, that all went well. I updated both of the devices firmware (latest) and now the satellite does not show in the admin co...
darthwhat57
Apr 10, 2022Aspirant
Nope neither worked. All it did was change the IP of the satellite. Appreciate the suggestions though.
Apr 10, 2022Guru - Experienced User
Where did you change the IP address of the satellite and what IP address did you change it too?
- darthwhat57Apr 10, 2022Aspirant
It changed on its own when I powered down the router.
- FURRYe38Apr 11, 2022Guru - Experienced User
So what IP address did it change to?
- darthwhat57Apr 11, 2022Aspirant
It was 192.168.1.3 and changed to 192.168.1.6 after the router power down. One thing i just noticed yesterday and it took a while for it show in the admin console (like a couple days) is that the satellite now shows itself int he admin console but shows as disconnected. Its definitely not disconnected as I can see it via IP address and I can see the devices connected to it. Can it take a few days for it show active again in the admin console?
