OrbiOrNot
Mar 21, 2024Initiate
RBR850 / RBS850 Firmware V7.2.6.21 Unstable (Slow or disconnected connection)
My setup: 1 RBR850 Router 3 RBS850 Satellites. Edgerouter V4 router for the house CAT6E cabling from router to RBR and to 2 RBS's for wired backhaul. All have a home run connection to my router. ...
Mar 21, 2024Guru - Experienced User
If the RBR is loosing connection and has a PINK front LED, means the RBR is not getting good internet from the upstream host router or there is an interruption in service from the host router to the RBR.
How is the RBR configured or AP mode? Static IP configuration is recommended as seen here:
There is no CAT6E cabling, There is CAT5E and CAT6. CAT6A STP is recommended with the RBR if you have a supporting 2.5Gb supporting connection port at the upstream host router. If not, CAT6 UTP would be recommended.
Yes, v7 adds a new IoT SSID Network feature which users have been asking for, for a long time to help with IoT devices:
I'd recheck this configuration again. I along with others tested v7 FW in AP mode last year and it worked well. One of the best FW versions in a long time IMO. There is one bug in the WEB UI not showing IP address information correctly on the WEB page is all. Just a graphical web UI issue is all.
