dglsmcd_USMC
Jul 10, 2020Luminary
RBR850 / RBS850 Firmware Version 3.2.15.32 - Hot Fix-Firmware Update
Addresses security issues-get it here: https://kb.netgear.com/000062077/RBR850-RBS850-Firmware-Version-3-2-15-32-Hot-Fix FURRYe38
Jul 10, 2020Guru - Experienced User
Kewl. Nat Filter for gamers is fixed in this version. Should be at least.
Chuck_M
Jul 12, 2020Mentor
For those that have RBS-50's hard wired to their AX systems -- there is also a corresponding upgrade to the RBS50 firmware found at:
https://www.netgear.com/support/product/RBK50.aspx#download
These potential updates are NOT announced by RBR-850 so you have to get them manually
RBR850, RBS850 and RBR50s took this upgrade very well (albeit manually installed) and are running smooth.
