dglsmcd_USMC
Jul 10, 2020Luminary
RBR850 / RBS850 Firmware Version 3.2.15.32 - Hot Fix-Firmware Update
Addresses security issues-get it here: https://kb.netgear.com/000062077/RBR850-RBS850-Firmware-Version-3-2-15-32-Hot-Fix FURRYe38
KMDonlon
Jul 12, 2020Virtuoso
Just loaded firmware and then one final reboot after the router & satellite were updated.
Jul 12, 2020Guru - Experienced User
Thanks.
- Chuck_MJul 12, 2020Mentor
I personally only loaded firmware in both the RBK852 and the RBS50s --- no factory reset.
- the5riversJul 12, 2020TutorI'm seeing a similar update for the RBR753s:
https://kb.netgear.com/000062075/RBR750-RBS750-Firmware-Version-3-2-15-32-Hot-Fix
I just got mine from Costco a few days ago. It automatically updated to 3.2.15.25 when I installed it. I'll try the newest update and see what happens.- FURRYe38Jul 12, 2020Guru - Experienced User
Let us know how it goes.
