dglsmcd_USMC
Jul 10, 2020Luminary
RBR850 / RBS850 Firmware Version 3.2.15.32 - Hot Fix-Firmware Update
Addresses security issues-get it here: https://kb.netgear.com/000062077/RBR850-RBS850-Firmware-Version-3-2-15-32-Hot-Fix FURRYe38
Jul 12, 2020Guru - Experienced User
I just updated to v32. I factory reset and setup from scratch here. I'm using default wifi CTS settings.
Port Address Restricted NAT is seen for NAT Filter set to open so I presume the bug that was fixed for me in a different version of FW hasn't made it to release yet. This was a minor hot fix so I'm hoping the NAT Filter fix will be in next major FW update.
I'm running default CTS values to see if I notice anything. Especially with my 3rd gen NEST. :smileyembarrassed:
ekhalil
Jul 13, 2020Master
FURRYe38 wrote:...... Especially with my 3rd gen NEST.
Is this NEST Protect? ;)
- FURRYe38Jul 13, 2020Guru - Experienced User
Thermostat.
- KMDonlonJul 13, 2020VirtuosoJust noticed I am getting far more than 7 log entries again and I have changed nothing on my end. How is this changing?
- Chuck_MJul 15, 2020Mentor
I am not. Mine is still at about 7
- FURRYe38Jul 15, 2020Guru - Experienced User
I'm only seeing 8. :smileyfrustrated:
