dglsmcd_USMC
Jul 10, 2020Luminary
RBR850 / RBS850 Firmware Version 3.2.15.32 - Hot Fix-Firmware Update
Addresses security issues-get it here: https://kb.netgear.com/000062077/RBR850-RBS850-Firmware-Version-3-2-15-32-Hot-Fix FURRYe38
Jul 27, 2020Guru - Experienced User
sl0thk1ng
Jul 27, 2020Aspirant
Yep, I applied it when it first came out just never notice it until today.
- FURRYe38Jul 27, 2020Guru - Experienced User
What browser are you using?
Facfory reset of the RBR after the update?
Heres mine with Opera browser:
- sl0thk1ngJul 27, 2020AspirantYes, I had to reset it because it was causing my Skype video to lag. Used chrome, Firefox, and edge same result.
- FURRYe38Jul 28, 2020Guru - Experienced User
Very odd. Is the system working ok?
Only thing I can think of is to downgrade back to v11, then re-up-load the v32 file again. I would besure to download the v32 file again from NG download page.
