Squibcake
Jun 21, 2022Follower
RBR850 / RBS850 Hard-Wiring Question
Hi! I have an RBR850/RBS850 system with the router and two satellites. I'm planning to add a few satellites because these system isn't big enough. I have an old house with a lot of plaster wall...
Jun 21, 2022Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Between the RBR and RBS if you ethernet connect the RBS to the RBR.
