dianneggy
Oct 08, 2022Aspirant
RBR850 / RBS850 in AP mode and wired backhaul
First time post. Setup is as follows: ISP modem only (no ISP router) connected to Netgear BR200 wired gateway (this is not a WiFi Router). The BR200 is set as the DHCP router and is in front of al...
Oct 09, 2022Guru - Experienced User
You need to connect these switches to the back of the RBR, not the BR router. The RBS need a segment line from behind the RBR to a switch then to the RBS. https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System 📡
peppercorn
Nov 06, 2022Tutor
Check your switch!
I recently encountered some unusual behavior with my Orbi WiFi 6 Router AX6000 (RBR850/RBS850). Performance has been pretty good over the past 2-years since I installed this system - replacing an older Orbi AC3000 (RBR50/RBS50) system.
My Verizon FiOS ONT (modem) was connected to a Netgear GS105 unmanaged GigE switch, and both my Router and Satellite are connected to this switch. Both my old and new Orbi systems have been working well in this configuration for a few years.
With my current system, over the past few months I have had issues where the Orbi app on my iPhone would not show the devices attached to my network. I was hoping that firmware updates would fix this, but no such luck (even with the latest firmware V4.6.9.11_2.3.5). I ended-up rebooting the system every few days to resolve this issue.
Most recently, the RBS850 satellite would not sync with the RBR850 router, and I could not get it to sync after trying a variety of recommended solutions. After a few days it started to sync again - and then lost sync again - and then regained sync again...
I decided to replace the 9-year old Netgear switch with a similar new TP-Link switch...even though the Tx/Rx lights on the old switch indicated that the switch was working properly. Situation resolved with the new switch installed! It's only been about 72-hours since I installed the new switch, but so far so good.
