fontygal
Mar 26, 2022Guide
RBR850 / RBS850 losing internet connection from Modem
I'm also experiencing disconnections of the RBR850 from the internet, roughly every few days. Some details: - The RBR850 is connected to a modem which I know is still providing an internet connecti...
- Mar 26, 2022
Update:
Firmware update worked (manually)
I'm such a dummy.
I didn't realize that there were TWO firmwares, one for the router and one for the satellite.
They are not the same file, and my error message above was because I was trying to install the router firmware update onto the satellite.
Anyways, I downloaded two firmwares, one for router, one for satellite.
I installed the satellite first
Then the router, as recommended.
Both installed, as you can see below.
And now I will wait and see if this fixed the problem of lost internet connectivity. Will let you know.
But please Netgear, we really should not have to go through this to update our firmware and have a stable internet connection. I should be able to do this from the Orbi app.
Thanks for the help of both the experts who contributed above. Really appreciate the goodwill people show in helping others. 🙂
CrimpOn
Mar 26, 2022Guru - Experienced User
The problem that caused this discussion was "experiencing disconnections of the RBR850 from the internet, roughly every few days" further described as "The RBR850 blinks pink when this happens, and then there is no internet signal available to any device in the house from the RBR850".
I fail to see how the "Double NAT" issue has any bearing on the problem. If fontygal has no issues with the Mac on one network and the rest of the house on a different network, the problem is that the Orbi connection fails too often.
The obvious first step is to update the Orbi to the current firmware level by using the manual firmware update option on the Orbi web interface. Not the Orbi 'app' (shudder). This is where the Double NAT is an issue. The only way to connect to the Orbi web interface is to be on the LAN side of the Orbi, not on the ISP router (nee modem) side. Here is where that longer ethernet cable comes in (temporarily). My own preference is to connect directly to the satellite web interface by using the satellite's IP address and selecting the Firmware Update menu option. Then connect to the router and navigate to the Manual Update tab.
I am not having success finding a user manual for the Orange Livebox unit. Would it be possible to post a web link to the product description? I ask because (a) if the actual optical fiber does not go directly into the Livebox, then perhaps the Livebox can be removed, and (b) the Orbi RBR850 has a 2.5G ethernet port. If the Livebox has a similar capability, then that entire 2G internet can flow to the Orbi.
Just to be clear, I do not oppose addressing the Double NAT, which has the potential to cause problems for specific situations,
fontygal
Mar 26, 2022Guide
Thanks so much. You are right, they are (most likely) separate issues, but I found both ideas really useful to consider, and I have a whole separate chat with some colleagues now on the NAT issue. More on that perhaps later, but for a long time, I have never had any issue with the Mac being on one IP from the Livebox Modem and the Netgear being on another (which then issues 10.0.0.X style IP addresses). I would think tons of people would have problems with their router to ISP modem connections if we always had to figure out bridge mode, NAT, DHCP settings, etc...maybe I'm super naive, but it strikes me that router companies would have to make that quite foolproof...just connect your router to your modem and the router does the rest (but I'm probably naive 🙂
Onto the good advice you give about firmware updating. In fact, I did exactly that already 🙂 . I connected directly to the Orbi router with ethernet and had a browser interact directly with the RBR850 router. I tried to manually update the firmware of the satellite, after I separately connected through a smaller window to the satellite RBS850. Then I tried to manually install the firmware. No go. Did not work. I will try again. you mentioned that you connected your ethernet line to the satellite not the router- would that make a difference?
About the Livebox, it's in French (I'm based in France at the moment) :-). But it does get the fibre line input. So there is no way around the Livebox.
This is a link to the manual:
In any case, so appreciative of the advice.
I'll give the hardwired connection and manual firmware update another shot, but this time with the a connection to the Satellite.
- fontygalMar 26, 2022Guide
Just to follow-up.
- I connected directly (ethernet) to the RBS850 satellite.
- Opened browser interface to the RBR850
- Went into Manual Update of Firmware, of just the satellite first as manual instructs, using the latest firmware Netgear offers for the RBR850
But the procedure failed again.
You can see the message below.
Question: is it risky to update manually the Router first and not the satellite?
Update:
I'm such a dummy.
- FURRYe38Mar 28, 2022Guru - Experienced User
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
