GetOverIt
Apr 30, 2021Guide
RBR850 + RBS850 Satellites: Terrible Performance & Stability
Previous setup: Modem Technicolor C2000T (CenturyLink) ISP Speed 1Gb Wireless 3 Apple Airports, all 3 plugged into walled ethernet. Performace was flawless across a two story, 3500 sq ft house, b...
May 01, 2021Guru - Experienced User
What mode is your modem/router working in? Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
How are you speed testing? With a wireless or wired device?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849
GetOverIt
May 01, 2021Guide
That reply is copy/pasted from every post on this same topic, and as I said, I've been through those. The firmware is irrelevant unless there is an actually documented bug fix on a specific firmware version. i.e. firmware 3.128 fixes ethernet connection issues. It is the lastest firmware available to the device at the time of posting.
Unless you live on a middle-of-nowhere farm, there are neighbors on wifi, and as previously mentioned in the original post, all the different channel options have already been tried. The system is expected to work reliably, like the Apple Airport did, regardless of the strangers that live in my neighborhood. Otherwise there would be a giant sticker on the box that says, "does not work in new york city."
The modem is already in modem only ode with the RBR in router mode. There are no other wifi antennas trying to control wifi traffic in the house.
Everything else is in the Netgear documention and knowledge base, so it doesn't help; it's been tried or taken into account, i.e. square footage and the coverage of each unit.
- FURRYe38May 01, 2021Guru - Experienced User
well if your not going to give feed back to the questions presented then might be time to return the Orbi AX and find something that works for you.
Good Luck.- GetOverItMay 02, 2021Guide
I have been able to gather additional patterns.
Using the status monitor for the c2000t modem, I found that the direct connection between the RBR850 and the modem drops to 100Mbps.
Running a speed test via the Orbi interface returns the connection between modem and the RBR to 1,000Mbps. It stay at this speed for a while and then drops down to 100Mbps again until I run another speed test.
IMPORTANT:
The ethernet ports on the modem have been tested, tested, and tested again. They are not the problem.
The ports on the modem are auto-sensing, so there is something on the RBR850 that eventually "tells" the modem its maximum speed is only 100Mbps.
The cable is not the issue; it has been tested multiple times using other hardware.
The modem is not the issue; again, it never had this problem with the previous wifi, and I have tested all the ports using other devices. Speeds nevers drops below 700Mbps.
It is ONLY the RBR85o that drops the speed between itself and the modem. I don't know why running a speed test would reset the RBR's port to full speed for a while.
- FURRYe38May 02, 2021Guru - Experienced User
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopTry either option #2 or #3. See if there is any changes.
Return the Orbi AX system and try another. Sounds like the RBR maybe faulty if it's not holding a 1000Mpbs connection rate at the modem in router or AP mode.
