PaulH23
Aug 17, 2022Guide
RBR850 / RBS850 Will Not Connect After Switching to AP Mode
I recently installed a Firewalla Gold firewall in router mode in my system and as a result, needed to switch my RBR850 (firmware version 4.6.8.2_2.1.9) from router mode to AP mode. After restarting the RBR850 in AP mode (it is connected directly to one of the Firewalla's eithernet ports via the RBR850's internet port), the RBR850 connected to the internet, my WiFi devices connected to it without problems and I can access it via orbilogin.com from my wireless devices (though not wired devices, but I believe that is normal behavior in AP mode).
Both RBS850s showed as disconnected (connected wirelessly and also on firmware version 4.6.8.2), so I power cycled them, but they still did not connect and their status LED was magenta (failed to sync).
I deleted both RBS850s from the RBR850 and tried re-adding them - no luck, both failed to sync and showed magenta status lights.
I factory reset one of the RBS850s and tried again - same result, sync failed, magenta status.
I've rebooted the RBR850 several times and tried to sync many times, including moving the RBS850s into the same room as the RBR850, all without success.
I've read several other threads regarding this issue, and think I've tried everything, though there doesn't seem to be one consistent procedure to follow, different things appear to have worked for different people.
Any suggestions on what I should try?
If you bring them (or start with 1) into the room with the RBR and direct wire it in, can you get the RBS to sync?
- PaulH23Guide
With one of the RBS850s directly connected to one of the RBR850s ethernet ports, sync still fails, but the behavior is different: the status LED on the RBS850 turns blue quite quickly, within a few seconds of starting the sync, however the RBR850 reports that the sync failed and shows 0 connected satellites. I can get to the RBS850s web page which reports "Your WIFI Orbi Satellite connection is up and running."
so when its hardwired in, you can access the satellite using its ip address?
If so, give it a few minutes to automatically sync and then disconnect it and see if it maintains/negotiates a connection over wireless.
