Dd852
Aug 18, 2020Luminary
rbr850 3.2.16.6 upgrade - I had difficulties and downgraded - be careful!
When I took the offered upgrade to 3.2.16.6 I ended up with a very odd issue. My two satellites (also upgraded, of course) worked perfectly but the main orbi router refused to connect any devices to ...
- Aug 26, 2020
Solved - finally
I'm a bit embarassed that the solution ended up being so simple. Finally after much fussing around, I did what I should have done earlier and simply sat near the offending router and did a long wifi scan. It turned out that even though I have the satellite approx. 30 ft away from the router, and even though everything had worked previously, after the firmware upgrade for some reason the 5 ghz signals clashed - they were very close in strength. And since Apple devices are a bit weird and fussy in how they decide what to attach to, I was creating a conflict the devices couldn't navigate through. I reduced the 5 and 2.4 signal strengths to 50% and all is good. I don't think I've created any black spote. Just another reminder that satellite placement and signal strength can be absolutely key.
Dd852
Many thanks. I think I might leave well enough alone at this point ... I broke rule number one which is , if it works well don’t upgrade unless the change seems truly necessary !
Dd852
Aug 26, 2020Luminary
Solved - finally
- FURRYe38Aug 26, 2020Guru - Experienced User
Glad you got it figured out. Thanks for letting us know.
Dd852 wrote:Solved - finally
