2ndRunner's avatar
2ndRunner
RBR850 500 Internal Server Error
I'm having an impossible time connecting to my router via the app (on 2 different phones) or via a browser (Chrome and Edge on different pcs).  Every now and then a can temporarily get in using the a...
  • FURRYe38's avatar
    Yes, prior backup configurations can re-introduce issues. Why it's best to FR and setup from scratch after newer FW has been applied. Then after it's all setup, save off a new backup configuration to file.
    Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a new back up configuration to file for safe keeping. Saves time if a reset is needed.
    Enjoy. 📡
