2ndRunner
Jul 31, 2024Aspirant
RBR850 500 Internal Server Error
I'm having an impossible time connecting to my router via the app (on 2 different phones) or via a browser (Chrome and Edge on different pcs). Every now and then a can temporarily get in using the a...
- Aug 01, 2024
Yes, prior backup configurations can re-introduce issues. Why it's best to FR and setup from scratch after newer FW has been applied. Then after it's all setup, save off a new backup configuration to file.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a new back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Jul 31, 2024Guru - Experienced User
What FW is loaded on the system?
