2ndRunner
Jul 31, 2024Aspirant
RBR850 500 Internal Server Error
I'm having an impossible time connecting to my router via the app (on 2 different phones) or via a browser (Chrome and Edge on different pcs). Every now and then a can temporarily get in using the a...
- Aug 01, 2024
Yes, prior backup configurations can re-introduce issues. Why it's best to FR and setup from scratch after newer FW has been applied. Then after it's all setup, save off a new backup configuration to file.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a new back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
2ndRunner
I'm saving that for a last resort since I have multiple static ip addresses setup and it would be chaos to redo. The firmware is the latest that came out in April but this issue started last month June
Jul 31, 2024Guru - Experienced User
I believe the only way to resolve this is thru a FR.
Also please keep on had a back up configuration. Saves time if a FR is needed.
- 2ndRunnerJul 31, 2024AspirantThat's one of my issues. I can't get into the router to back it up
- FURRYe38Jul 31, 2024Guru - Experienced User
IF thats the case then ya, lets FR and setup from scratch using the following process outlined in the PDF:
- 2ndRunnerAug 01, 2024Aspirant
Update. I managed to get in with just enough time to back up my settings without getting the error. This morning, I reset to factory. Everything was back in working order, but as soon as I applied the backed up settings, it started doing the same thing. I reset one more time, and reconfigured everything manually. My guess is I had a certain setup that did not agree with the latest update and just froze the router.
Hopefully, this will help someone having the same issues.
Thank you!
