2ndRunner
Jul 31, 2024Aspirant
RBR850 500 Internal Server Error
I'm having an impossible time connecting to my router via the app (on 2 different phones) or via a browser (Chrome and Edge on different pcs). Every now and then a can temporarily get in using the a...
- Aug 01, 2024
Yes, prior backup configurations can re-introduce issues. Why it's best to FR and setup from scratch after newer FW has been applied. Then after it's all setup, save off a new backup configuration to file.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a new back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
2ndRunner
Aug 01, 2024Aspirant
Update. I managed to get in with just enough time to back up my settings without getting the error. This morning, I reset to factory. Everything was back in working order, but as soon as I applied the backed up settings, it started doing the same thing. I reset one more time, and reconfigured everything manually. My guess is I had a certain setup that did not agree with the latest update and just froze the router.
Hopefully, this will help someone having the same issues.
Thank you!
Aug 01, 2024Guru - Experienced User
Enjoy. 📡
