Compguymn
Feb 12, 2021Aspirant
RBR850 and Amazon Alexa and Cisco IP phone
Hi, I have had my Orbi for months now with a Bose soundbar 700 with Alexa and an Amazon Alexa Show. I also have a Cisco IP phone connected to work via vpn. Everything has worked wonderfully for 6 mon...
Feb 13, 2021Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).
- CompguymnFeb 13, 2021AspirantHi. I’m running an Aaros surfboard 8200 with Mediacom cable 1gb service. Router firmware is 3.2.16.22. I tried auto updating firmware but it doesn’t recognize there is a newer .17 version out there. Home is 3000 sq ft with router on bottom floor northwest corner and RBS on middle floor northeast corner.
I will try your ideas one at a time to see if one may work.
Again nothing in my environment has changed. Firmware was on auto update so that could have changed.
