Compguymn
Feb 12, 2021Aspirant
RBR850 and Amazon Alexa and Cisco IP phone
Hi, I have had my Orbi for months now with a Bose soundbar 700 with Alexa and an Amazon Alexa Show. I also have a Cisco IP phone connected to work via vpn. Everything has worked wonderfully for 6 mon...
Compguymn
Feb 22, 2021Aspirant
I am updating the firmware mannually today then will monitor. A frustrating situation.
Feb 22, 2021Guru - Experienced User
I'd probably do a factory reset and setup from scratch after the update if the problem continues.
- CompguymnFeb 22, 2021Aspirant
The test was short lived. The issues are still present. Will have to wait for the weekend when computers are not in use to start from scratch.
- FURRYe38Feb 22, 2021Guru - Experienced User
Ok.
- CompguymnFeb 23, 2021Aspirant
So this is odd(actually not odd at all). With the updated firmware I changed the default channels on the 5 and 2.4 wireless. I think I picked 44 and 11. My ip Cisco phone would not register at all. I put the channels back to default and everything is working so far. I guess I should have done what I said I would do and only change one thing at a time. I will monitor today working from home. Thanks again for your suggestions
